is this knock sensor fixable?
Old Aug 13, 2003 | 06:13 PM
daver's Avatar
Default is this knock sensor fixable?
when i unplugged it, the cap came off as you can see. that little wire on the left piece, i'm assuming was soldered to that clump on the right piece. that thing sticking up on the right is like some ceramic shielding or somthing. It slides right down inside, but its partially broken.
Anyone had one of these apart before?
d
Modified by daver at 3:24 AM 8/14/2003
Old Aug 13, 2003 | 06:16 PM
mr.beeks's Avatar
Default Re: is this knock sensor fixable? (daver)
sorry to burst your bubble but its not fixable
only replacesable.
Old Aug 13, 2003 | 06:25 PM
daver's Avatar
Default Re: is this knock sensor fixable? (francisco flores)
are you sure? I might be able to resolder it, if that is indeed how it went. these things are so bloody expensive
Old Aug 13, 2003 | 06:31 PM
mr.beeks's Avatar
you could try to resolder
and use an exposy to put it together
and check if it gives you the specified reading with a tester
Old Aug 13, 2003 | 06:34 PM
daver's Avatar
any idea how to test it francisco?
Old Aug 13, 2003 | 06:41 PM
mr.beeks's Avatar
using a multimeter http://www.sears.com/sr/produc...16000
after putting the sensor back together test it and compare to the reading
to OEM specifications
Old Aug 16, 2003 | 04:39 AM
toolowsol's Avatar
ummm you can't test a knock sensor with a multimeter, you need an oscilliscope, which i highly doubt you have laying around I just took mine into my physics lab and tested it by tapping it with a hammer while scanning, mine was bad, checked a new one and it worked, put it in the car, and it was fine You can't use a multimeter because the knock sensor sends out a damped sine wave, not a constant voltage.
Old Aug 16, 2003 | 04:40 AM
toolowsol's Avatar
Default Re: is this knock sensor fixable? (toolowsol)
to answer the original question, no, you can't fix it, they are much to sensitive, if you put a glob of solder on it, it would through the balance and wieght off and the sensor would send out a different signal.
Old Aug 16, 2003 | 10:08 AM
TeStUdO's Avatar
you can chack a KS with a multimeter. switch the voltmeter to the lowest AC voltage scale put the negative side to the sensor body, and the positive side to the sensor terminal. with the voltmeter attached to the sensor tap on it with a hammer and you should get fluctuations in voltage, if it doesnt fluctuate the sensor is bad. you should do it with the sensor removed and the wiring harness connected to it. i have done it with it still connected though. but i would buy a new one that one looks kinda shitty. you could always test it though. good luck.
Old Aug 16, 2003 | 11:28 AM
toolowsol's Avatar
Default Re: (TeStUdO)
the only proper way to test a knock sensor is with an oscilliscope.
Old Aug 16, 2003 | 11:53 AM
REESE1's Avatar
Default Re: (toolowsol)
does that only apply to knock sensors? Can a oscilliscope be used for other sensors? Where can you buy them?
Old Aug 16, 2003 | 12:07 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">the only proper way to test a knock sensor is with an oscilliscope.</TD></TR></TABLE>
not everyone has one a hammer and multimeter works fine, i have the knock sensor bypassed on my car anyway. thats not reccomended though
Old Aug 16, 2003 | 02:06 PM
GSpeedR's Avatar
Oscilloscopes are quite expensive. (I use a $10,000 one at work, but that's a different story). However, you can buy a small one for $300-$400. Go to the library and check out a Physics Review Journal: such as Physics Review Letters A, B, or C, or something like that. There are tons of ads for experimental equipment such as this.
However, why the hell would you waste your money on this, simply to test a KS? Go buy a new one.
Old Aug 16, 2003 | 03:32 PM
daver's Avatar
Default Re: (GSpeedR)
thanks guys, i bit the bullet and ordered a new one from acura, no fooling around for me. 162$ cdn tho, ouch.
Old Aug 16, 2003 | 06:41 PM
Stripped Honda's Avatar
99-0104
Default Re: (daver)
that is actually cheap i ordered one today for a nissan altima for a customer at work and it was 170 us dollars my cost! retail is like 215.00
Old Aug 17, 2003 | 12:45 AM
TeStUdO's Avatar
you could ket a used KS from someone on this board for like 50 bucks im sure
Old Aug 17, 2003 | 02:18 AM
daver's Avatar
i did take a quick look for used ones, not the same generation, used with an unknown background (sounds like they're delicate) and from stangers and probably a a longer wait. No fooling around for me.
thanks
Old Aug 17, 2003 | 03:01 AM
eg_type_r93's Avatar
nope
Old Aug 17, 2003 | 09:52 AM
LudeyKrus's Avatar
mine did the exact same thing; too bad it's not fixable....
Old Aug 17, 2003 | 10:57 AM
irev210's Avatar
Default Re: (LudeyKrus)
yeh i sell them for 50 bux shipped US dollars...
honeslty, im curious as to how you figure the ecu works to the same degree and precision as an ocilliscope.
I always did the same thing, test it with the hammer of the block technique and it was intresting how the knock sensor would jump around. Im 90% sure that just like the TPS and map sensor, its based off voltage, and if the voltage changes, then the ECU makes corrections, and im sure it only samples so many times per second. I think you saying the ONLY way how to test a knock sensor is wrong. Im sure that one is perhaps more precise then another method, but you need to look at how the sensor is going to be used. In most case senarios, high performace hondas dont even use the knock sensors w/ chipped programs/hondata/aem ems etc
Old Aug 17, 2003 | 11:15 AM
LudeyKrus's Avatar
Default Re: (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">yeh i sell them for 50 bux shipped US dollars...
What do you sell for $50 shipped?
Old Aug 17, 2003 | 11:57 AM
Rob Dizzle's Avatar
i did the same thing.
it might be fun to strap it to some fireworks or burn it, besides that its toast
doublezerohatch
12
Jun 4, 2013 03:20 PM
SuperBowser707
Dec 4, 2012 07:49 AM
b18cEF9
Aug 28, 2004 07:17 PM
daver
Aug 16, 2003 03:33 PM
93NXLUDE
Mar 5, 2003 06:32 PM
