key on ignition no power no lights nothing
Old Sep 14, 2009 | 01:58 PM
articsilber323's Avatar
Default key on ignition no power no lights nothing
i bought a 92 civic shell and just got done swapping my b16 into it
problem im having is when i turn the key on nothing comes on
the main relay does not click
the fuel pump does not work
no cluster light come on the ecu or anything
does anyone have any idea what it could be i have checked all the fuses and replaced the main relay
please help
Old Sep 14, 2009 | 11:17 PM
j-dmek9's Avatar
Default Re: key on ignition no power no lights nothing
idk if u did, but double check the fuses.. under the hood theres the fuse box and check for the FI E/M fuse the first top left corner, if its out then u'll get nothing, no click or spark or fuel pump priming, also it could be ur ignition switch!
Old Sep 16, 2009 | 09:21 AM
abelkayn's Avatar
did you also check your ground conections, theres one on your thermostat housing and the main one from chassis to transmission? also did you check the connection from starter and battery and to the fuse box, that might be corroded
Old Sep 16, 2009 | 12:01 PM
j-dmek9's Avatar
true that...
Old Sep 17, 2009 | 02:33 AM
.Manny.'s Avatar
Touching My Member
check the battery fuse in the engine bay fusebox
Old Sep 17, 2009 | 05:54 AM
fcm's Avatar
fcm
Old Fart
Do you have any power at all, head lights, horn, dome light or radio?94
Old Sep 18, 2009 | 10:07 PM
civickiller's Avatar
something like this happen to me, ground from valve cover to radiator support
2ndthtsurplace
48
Sep 2, 2011 12:45 PM
f20cmx5
11
Mar 25, 2011 04:57 PM
articsilber323
32
Oct 26, 2009 02:44 PM
JDM_CRX_PLEASE
21
Jan 16, 2008 02:21 AM
dubshack
Jul 11, 2004 06:24 PM
