Main Relay?
Main Relay?
Today I was going to start my k20a2 swap with a hybrid racing harness. The fuel pump primed and I started it no problem. I turned it off and went to turn it back on again and the fuel puitp didnt prime. Also, the check engine light no longer showed up. Is it the main relay? Any fuses I should check? I already checked the "ecu" fuse in the black fuse box
Re: Main Relay?
kick the relay a little to see if it is just the solder joints giving out after 20 years of existence.
Then kick yourself if you've replaced anything before trying this, if it works.
