K20a2 on an engine stand. What length of bolt?
Old Sep 14, 2005 | 04:40 AM
k-series's Avatar
Default K20a2 on an engine stand. What length of bolt?
I know that I need a 12/1.25 bolt, but what length? I'm thinking about 6" (150/160mm) so that it can fit through the tube for the engine stand and still thread into the block as well.
Am I missing something, is there another way I should be getting this motor on this stand?
Steve
Old Sep 14, 2005 | 08:38 AM
(puma)'s Avatar
Default Re: K20a2 on an engine stand. What length of bolt? (k-series)
im having the same problem except i need to bolt a b16 onto my engine stand. but actually a couple of people have said to use your transmission bolts, as they should fit perfectly, i just cant seem to find any. any other opinions?
Old Sep 14, 2005 | 08:41 AM
k-series's Avatar
Default Re: K20a2 on an engine stand. What length of bolt? (B_Series)
Just swung by a specialty hardware store and got 4 12/1.25 x 120mm bolts... $21.20.
But, at least I'll have them now.
Steve
Old Sep 14, 2005 | 06:48 PM
Wes V's Avatar
I ordered 12mmX1.25 threaded rod from McMastercarr and cut it to length.
Old Sep 15, 2005 | 01:55 AM
k-series's Avatar
Default Re: K20a2 on an engine stand. What length of bolt? (Wes V)
Let me ask you a question then. Don't you need the bolt head to be snugged up against the "arms" of the engine stand?
I'm asking this becaue the bolts I got are about 3/4" too long and I'm concerned that they may fail or bend due to the amount of stress on them.
Steve
Old Sep 15, 2005 | 06:45 AM
Mike@CCT's Avatar
Formerly Mike@TSR
i used front crossmember bolts from a crx for my k20 on the stand
Old Sep 15, 2005 | 08:51 AM
Wes V's Avatar
Default Re: K20a2 on an engine stand. What length of bolt? (Mike@TSR)
K;
If you use threaded rod, you can lightly screw them into the block until they bottom out. Then use a nut and washer on the other side of the engine stand bracket. That's as good as it gets because you are catching <U>all</U> of the threads in the block.
Wes
Old Sep 15, 2005 | 09:15 AM
k-series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">K;
Wes</TD></TR></TABLE>
Damn...thinking ownz me.
Is the below what you got (basically)?
Part Number: 95245A110 $27.89 Each
ASTM Specification ASTM A193
Material Type Steel
Finish Plain
Grade/Class Grade B7
Type Fully Threaded Rods and Studs
Steel Type General Purpose Steel
Thread Direction Right Hand Thread
System of Measurement Metric
Thread Size M12
Metric Thread Pitch 1.25 mm
Overall Length 300 mm
Specifications Met American Society for Testing and Materials (ASTM)
Rockwell Hardness C24
Minimum Tensile Strength 125,000 psi
Notes Class 6g thread fit
I think I'll get 2 300mm and cut them in half. But damn, over $50 for these things.
Steve
Old Sep 19, 2005 | 03:53 AM
k-series's Avatar
I think I found a solution to my problem I just added a nice stack of washers to fill the gap on the stand side and the motor is finally sitting correctly. It's a little cheaper than buying all new bolts/rod.
Steve
aznguy0087
Jul 5, 2007 11:22 AM
mountaindewguy
Jan 31, 2006 10:11 PM
jbell
Jan 6, 2005 10:55 AM
Matgallis
Aug 25, 2004 02:36 PM
93preludes
Jan 5, 2003 01:38 PM
