k20a too HOT
Old Dec 1, 2009 | 07:03 PM
BrendanJ85's Avatar
Default k20a too HOT
Hey all I have a little problem with my newly purchased k swapped DC. I was in the drive thru it got pretty hot and blew off a line I shut it off let it sit for a minute or two and parked it in a safe spot. Let it cool down and drove over to autozone no problems I have a mishimoto radiator and an electric fan wired to my ignition but come to find out fan wasn't working ground came loose. Hooked it back up drove around no problems nice and cool (don't have a temp gauge so not sure of the numbers, its on the list though). Now every time the car sits for over 5 minutes or so at idle with fan on all the time it is still getting hot. Now when I over heated in the drive thru I lost a good bit of fluid, so grabbed some water filled it up, then drained the water from the radiator fitting on the bottom filled it back up with 50 50 mix. Also, the car does not have a thermostat. Both upper and lower get pretty warm when sitting. Any ideas? Thanks sorry for the long post.
Old Dec 1, 2009 | 07:09 PM
JBN241's Avatar
Default Re: k20a too HOT
you NEED a thermostat
Old Dec 1, 2009 | 07:31 PM
BrendanJ85's Avatar
Not that I'm doubting you OR disagreeing with you but I have read stories on k20a about how people have been overheating with the thermostat took it out and it runs perfectly corecy temperature so I just assumed that wouldn't be the problem? I am planning on getting one I am not sure which route to go with it though just get one from though.
jdmspoonitr
Oct 13, 2006 05:10 PM
plshrk
Jul 25, 2005 07:58 PM
coupon
Jul 21, 2005 10:42 AM
LoooseGSR
Jul 15, 2003 10:49 PM
