Just dropped motor in, trying to get it running right.
Old Apr 20, 2003 | 10:37 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Just dropped motor in, trying to get it running right.
I dropped in my B20vtec (OBDII, EK Hatch) last week and so far put 600 miles on it. It's not running perfectly yet. Here are a few of the symptoms:
1. The idle varies from 600rpm to 1,700rpm from time to time. Sometimes it gets so low that the engine dies.
2. Sometimes when accelerating, my reving becomes "restrictive" around 2.5-3K rpm. I give it gas, but it barely goes anywhere. And sometimes it jerks.
3. I have a sprung 6 puck clutch. It's hard to engage in first gear unless I give it around 2.5-3K rpm at a normal driving take off. Any less than that range of rpm during clutch engagement and the whole car will jerk.
*Possible causes:
-FPR, too low of pressure?
-Bad distributor
-2 (two) O2 senors hanging out of it's socket
-Using a First Gen B16 TB, bad TPS?
-Timing
These are just a few things that I suspect. It's not throwing any codes. If any of you guy have experienced any of these, please help me out. TIA.
Old Apr 21, 2003 | 12:15 AM
torr's Avatar
Default Re: Just dropped motor in, trying to get it running right. (GapxGuy)
fpr or ecu
Old Apr 21, 2003 | 05:31 PM
GapxGuy's Avatar
Anyone else?
Old Apr 21, 2003 | 06:35 PM
salbaje's Avatar
idling might be related to timing. is it throwing any codes?? what ecu are you running?
Old Apr 21, 2003 | 07:09 PM
chad174's Avatar
Default Re: Just dropped motor in, trying to get it running right. (salbaje)
I'm having the same type of problem with my obd 0 b18a in my 89 crx. hmm..check my post in the crx forum maybe for a little help...except im getting a code 14...EACV. or IACV or whatevr.
Old Apr 21, 2003 | 07:27 PM
GapxGuy's Avatar
Default Re: Just dropped motor in, trying to get it running right. (chad174)
It's not throwing any codes, I'm using an ITR ecu.
joiv21
Jun 9, 2013 11:31 PM
johnzy00
15
Jan 19, 2010 09:10 AM
Lightsped
Feb 12, 2009 02:59 PM
Lightsped
Feb 12, 2009 10:50 AM
aquabob89
Apr 24, 2006 09:32 AM
