gsr swap in ek no power help
Got the timing right it was off a tooth. Fixed all vacuum leaks now have around 15inches at idle. Great throttle response in neutral but nothing when clutch is engaged.
Can anyone please help?
Re: gsr swap in ek no power help
Can rev engine and the higher rpms will allow the car to move and keep up to maybe 7-8 mph but when i excel (or try to) nothing. no codes!
anybody got any insight would be greatly appreciated. Fuel pressure is good. Around 40 at idle wot jumps up to 50+
oh lol.. yah sounds like your clutch is slipping lol.
if you rev the **** out of it the car will move foward slowly.
you need a clutch ;-)
Sorry With clutch disengaged raise the rpms then apply the clutch it will allow it to move but once the rpms come back down it will stall out because i'm not able to accellerate.
im not even sure, it could be that the synchros are gone or the gears themselves are ground down to crap. My friend blew his tranny and when he blew it, when he put it in most of the gears the car would bog, start tripping, and stall.
can you go into any gears sounds like tranny might be stuck in a high gear may 4th or 5th but if you can slip the clutch car will start rolling, can you get the car above 7-8mph
lsvtek
17
02-26-2011 06:22 PM
