Fuse Problem . . . need help
Old 05-04-2002, 11:56 PM
-Racer X-
Guest
Posts: n/a
Default Fuse Problem . . . need help
hehe, ok heres the deal, my fuse for my tailight/dash lights keeps blowing no matter what fuse i put in it, it takes a 15 stock, i tryed em all, 10-30 and they all blow, the only power changes i have made to my car is new JDM 1-peice headlights (for DA9), my tailights worked even after i installed them, so i dont know if that is a part of the problem...but the fuse keeps blowing, im just wondering if anyone knows whats going on...
thanks in advance
Old 05-05-2002, 07:20 AM
rainforest's Avatar
Default Re: Fuse Problem . . . need help (-Racer X-)
sounds like you keep on shorting out the wire check to see if any of the wires are touching.
Old 05-05-2002, 09:06 AM
-Racer X-
Guest
Posts: n/a
Default Re: Fuse Problem . . . need help (rainforest)
what wires?
Old 05-05-2002, 09:55 AM
Jared's Avatar
Take out your tail light bulbs and install the fuse, then start installing bulbs until the fuse pops, then you have either found a problem bulb or a short in the wiring up to that point. but NEVER install a bigger fuse than factory, you're asking for a fire if you do that.
Old 05-05-2002, 10:02 AM
-Racer X-
Guest
Posts: n/a
yes instantly as soon as i turn on the headlights
Old 06-30-2013, 04:56 PM
Lindseys's Avatar
Check the headlight switch...
queda
05-23-2008 08:42 AM
asubennett
08-27-2004 10:13 AM
dip-set
07-18-2003 07:32 AM
-Racer X-
05-05-2002 09:56 AM
Quick Reply: Fuse Problem . . . need help
