help with fuse problem
Old Jul 12, 2003 | 09:24 PM
dip-set's Avatar
Default help with fuse problem
i was driving tonight and my drivers side low beam went out..i thought it was the bulb so i put my stock one in...not the problem..i check the fuse and it was blown..so i replaced the drivers side low beam fuse and the second i turned on the headlights it popped again..tried another fuse ,,popped again soon as i turned on the headlights...what could be causing the 10amp drivers side low beam fuse to keep popping..
note: ive been running piaa extreme whites for the past 8 months without a problem till this..
car is a 96 integra se..
TIA
Old Jul 17, 2003 | 11:00 PM
tegmech's Avatar
Most likely its grounding out. Check the wires up by the headlight to see if there is a bad connection somewhere or bare wire. Then replace that section of wire.
Old Jul 18, 2003 | 07:32 AM
dip-set's Avatar
Default Re: (tegmech)
i got it fixed...thanks...
-Racer X-
Jun 30, 2013 04:56 PM
d16trexin
Lighting
Dec 9, 2008 09:11 AM
EG9_808
Aug 29, 2006 01:57 PM
obsidianG35
Sep 12, 2003 01:50 PM
