JB weld work for b-pipe exhaust crack?
Old Feb 25, 2003 | 08:12 AM
MeanGreenEG9's Avatar
Default JB weld work for b-pipe exhaust crack?
I know JB weld works well on metals and non-moving parts so I wanted to use it on my b-pipe which has a hairline fracture or "crack" on it.. It calls for a maximum temp of 300C... do you know how hot the b-pipe can get on a NA car with basic mods? I'm not sure if JB weld can hold the heat.. anyone?
Old Feb 25, 2003 | 08:15 AM
Jeff C's Avatar
Default Re: JB weld work for b-pipe exhaust crack? (B16aEJ)
I put it on a pin hole that I had on the down pipe and it held up.
Old Feb 25, 2003 | 11:03 AM
Default Re: JB weld work for b-pipe exhaust crack? (Jeff C)
Thanks jeff for your input.. anyone else use it on an exhaust pipe of some sort? I need to spread it over a pretty large crack on my pipes but the crack is still pretty sealed or closed up if that makes sense...
Old Feb 25, 2003 | 01:38 PM
Jeff C's Avatar
Can you take it off and take it to an exhaust shop to put a bead of weld on it?
CRX Si69
Welding / Fabrication
Apr 17, 2012 03:08 AM
boca
Jun 29, 2009 06:43 PM
1SlowSi
Mar 28, 2005 01:55 PM
rough_draft
Nov 17, 2004 06:07 AM
