<><><><><><>REMOVING THE MID EXHAUST PIPE HEAT SHIELD?? IS IT OK??<><><><><><><>
CAN I REMOVE MID EXHAUST PIPE HEAT SHIELD CAUSE MY EXHAUST RATTLES?.....ITS A APEXI EXHAUST...
Re: <><><><><><>REMOVING THE MID EXHAUST PIPE HEAT SHIELD?? IS IT OK??<><><><><><><>
If you are referring to the shield that is attached to the tunnel, I wouldnt recommend it. You can get it tack welded. If its on the actual pipe, then yes, it wont make a difference.
nothing would happen i dont have no heat shields on my exhaust. i have no problems
cennouu
15
01-12-2011 07:30 PM
