ITR Problem
Old Aug 19, 2004 | 08:00 PM
PolishRacing1's Avatar
Default ITR Problem
i have a little problem with my 97ITR swap into a 93civicSi. i let the car warm up i checked all the wires everything is good the MSD Ignition and blaster coil r new and were wired up by a pro. so the problem is when ever i step on the gas it started to bog down like it is missing something so if anyone has any advise i would really love it
Old Aug 20, 2004 | 12:40 PM
EF9-G'zer's Avatar
Default Re: ITR Problem (PolishRacing1)
What kind of ecu are you running? Are you getting any CEL's?
Old Aug 22, 2004 | 07:17 AM
Default Re: ITR Problem (EF9-G'zer)
the kind of ecu i am using and was working for the longest time is i think a chipped gsr one but im not sure on that
Old Aug 22, 2004 | 07:47 AM
LSVTEC 91 Civic's Avatar
Banned
Could be timing.. could possibly be running too rich...
Old Aug 22, 2004 | 08:02 AM
mmuller's Avatar
Mad Scientist
Default Re: ITR Problem (LSVTEC 91 Civic)
yep, could be timing or your msd is giving you chit.
Old Aug 24, 2004 | 10:57 AM
Default Re: ITR Problem (mmuller)
but wouldnt the timeing let u rev up higher then 2000 rpm and how would i kno if i was running too rich..... i was also thinking about switching the wiring harness and suggestion on what kind i should get
Old Aug 24, 2004 | 12:09 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolishRacing1 &raquo;</TD></TR><TR><TD CLASS="quote">but wouldnt the timeing let u rev up higher then 2000 rpm and how would i kno if i was running too rich..... i was also thinking about switching the wiring harness and suggestion on what kind i should get</TD></TR></TABLE>
Oh, i didnt know that you cant rev over 2k.
if you cant rev over 2k and you have no cel then is most likely the msd. take out and see
Old Aug 24, 2004 | 02:43 PM
what is cel on the msd i dont get what that means
Old Aug 25, 2004 | 05:37 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolishRacing1 &raquo;</TD></TR><TR><TD CLASS="quote">what is cel on the msd i dont get what that means</TD></TR></TABLE>If your ECU isn't setting off the Check-Engine-Light (CEL), then the trouble is probably in your ignition system.
Old Aug 25, 2004 | 06:33 AM
Default Re: ITR Problem (JimBlake)
thanks for the info i really apriciate it
Old Aug 29, 2004 | 05:06 PM
i changed the msd to a msd 6al and i set the rev limiter on it to 7000 and it still does the same thing what else could the problem be
Old Aug 29, 2004 | 05:46 PM
IH82LOSE's Avatar
I had this similar problems my spark plug wires were cross. Make sure they are in the correct order. Good Luck
Old Aug 29, 2004 | 06:29 PM
PHiZ's Avatar
Default Re: ITR Problem (IH82LOSE)
TPS and MAP switched.
-PHiZ
Old Aug 30, 2004 | 09:27 PM
-=Zeqs=-'s Avatar
Make sure the connections on the MSD coil is clean and there isn't any electricial arching between the positve and negative poles. I had something similar happen to me before when I ran a Blaster SS coil without proper shielding.
Old Sep 1, 2004 | 10:35 AM
Ministry's Avatar
this might sound silly but check all your grounds. my car did essentially the same thing the first time I fired it up and it was due to a loose ground. I thought everything was tight but the vibration of the motor (at idle) loosened one of the grounds. tightened it up and problem disappeared
Old Sep 14, 2004 | 11:37 AM
alright its been a while since i worked on the swap. i did what everyone suggested and i got the enigine to rev up higher but still no vtec. before the car had less power then it did now but it feels like the car has absolutly no torque. i kno it aint anything in the tranny since its a new clutch flywheel and fluid and i had the tranny checked out so i dunno anymore if anyone could help i would love it
noluckracing
Engine Management and Tuning
Sep 14, 2009 04:38 PM
Dartanian
Mar 26, 2006 06:48 PM
SOHC_MShue
Jul 7, 2005 06:36 AM
Big James
Jul 13, 2001 01:55 AM
