ITB question (Honda 929) .. what is this:
Old Jul 9, 2004 | 07:21 PM
redlineintegra's Avatar
Default ITB question (Honda 929) .. what is this:
#4 and the assembly accompanying #7 .. from what I can see on my 929s, it looks like some kind of air control valve, with a manual adjusting nut? I just want to know if it's necessary to use on my motor, I can't see any issues with not using it. Ideas anyone?
Old Jul 9, 2004 | 09:19 PM
user 996328629's Avatar
Default Re: ITB question (Honda 929) .. what is this: (redlineintegra)
You dont need the #7 thats essentially a FITV, all u need is to keep the #4 setup to adjuse idle air inlet.
Old Jul 9, 2004 | 09:51 PM
Default Re: ITB question (Swags04)
Thanks for the info, exactly what I needed to know
Old Jul 22, 2004 | 09:07 PM
Xgen's Avatar
Default Re: ITB question (redlineintegra)
bad info, the #7 is just a hose, it controlls the #4 assembly, which you do need to controll the idle. what you dont need is the thing above the hose, the air thing, i cut mine off.
Old Jul 23, 2004 | 08:56 PM
Default Re: ITB question (honda_guy_83)
Good thing I am lazy and haven't gotten around to starting on the ITBs hehe .. so you eliminated the metal piece (fitv), and kept just the idle adjusting screw?
Old Jul 24, 2004 | 06:16 AM
u adjust ur idle up and down by that hose...
Old Jul 24, 2004 | 11:24 AM
OTT's Avatar
OTT
wht are these itbs from and what engine are you intending to use them on?
snw56
Honda CR-V & Element
12
Nov 29, 2024 01:09 PM
addikted2wips
Jan 20, 2008 05:05 PM
fe519
Nov 8, 2004 06:08 AM
b16acrxer
Aug 31, 2004 09:02 AM
