issues w/ b16a
Old Sep 14, 2009 | 08:51 AM
coryfenton's Avatar
Default issues w/ b16a
Hey guys im having a bit of a problem in my sol.... I bought it with the b16a swap already, and it came with and was running on a p28. Well with the p28 in, it started to kind of lag out in vtec. So I checked the oil levels, the timing, and then thinking it coulda been a spun bearing like my ls vtec did. I took off the valve cover, vtec selonoid and the oil pan... Everything looked pretty clean with no debree or metal shavings.
So I did some more searching online, some people were having the same issues and said that they swapped ecu's to a p30. So I got a usdm obd1 p30... Solved the sputter/lag during vtec problem, but now with the usdm p30 it will kinda lag before vtec. Feels like it isnt getting enough fuel or something..
SO then I replaced the plugs, wires, fuel filter, and the oil change.. Still lagged before vtec.
I was then told that using a JDM p30 it should be ok cause the motor is a jdm swap?
Got the jdm p30 and it still has the lag before vtec problem...
Do you guys have ANY idea's of what this could be??
CanoTech88
21
May 2, 2012 04:32 PM
TeggyBear_Ls
Dec 21, 2009 03:03 AM
coryfenton
Sep 10, 2009 09:35 AM
DarikDisease
Aug 26, 2008 01:29 PM
chachi1080p72
Nov 6, 2007 04:28 PM
