Single Click and Occasional Start
Hey guys. I have a 93 Civic Dx Sedan with a b18b1. I am having a problem starting my car. Everyone now and again when I go to start my car it will just do a single click and sometimes it will start right up. The sound appears to come from under the dash but people outside the car and hear the sound too. I have taken it to my friend and he tested the battery and the starter and they both came back good. I have also tried having someone tap on the starter while I trying starting it and sometimes it works and sometimes it doesn't. Its been suggested to me that the ignition switch could be bad, the starter itself could be going bad, or it could the the starter solenoid. I was curious if anyone else has had this problem and what they did to resolve it. Thanks in advance
are your positive and negative wires on the starter corroded?
try this
http://www.b20vtec.com/forums/b-seri...sis-101-a.html
try this
check for corrosion on the starter terminal,
your solenoid may click and bridge the B to the M terminal, but corrosion can prevent current from flowing
and with it being an intermittent problem, a high resistance of the sort is present somewhere in the starting circuit (most likely the starter terminals or main relay)
Never checked the terminals for corrosion. Probably should have done that too while I was checking the grounds. I will check the terminals and main relay tomorrow. Thanks for the help all.
The single click noise suggests that the ignition switch and starter solenoid are fine.
If the large starter wire and the transmission ground wire connections are fine, have the starter retested at another shop or store.
The main relay has nothing to do with the starter.
Unless I misread the first post, this is a no-crank problem (starter won't turn engine). A bad main relay would not cause a no-crank problem.
Thanks for all the info. When I get the click sound the engine doesn't start. The car started fine this morning. I'm going to check the connections to my starter later today and get the starter retested too.
SHITTY CONNECTION. i envision two repeatedly over-torqued, rabid looking, otherwise completely assed-out looking battery terminals.
that's all. if i'm wrong, i'll paypal op an ice cream sandwich. in for results.
usually you just need a solenoid rebuild kit as the contacts and plunger get worn down and bite the dust.
https://www.ebay.com/itm/31491071842...Bk9SR6CcneeTYw
hatcht9x
Dec 20, 2023 09:38 PM
JPerkMr954
Jun 9, 2013 08:51 PM
