Intake Valve Opening Crank Angle BTDC
Old Feb 25, 2004 | 02:44 PM
HmgLauj69's Avatar
Default Intake Valve Opening Crank Angle BTDC
quick question, what is "Intake Valve Opening Crank Angle BTDC"? and what is it for a stock b18b?
Old Feb 25, 2004 | 03:30 PM
IN VTEC's Avatar
Default Re: Intake Valve Opening Crank Angle BTDC (HmgLauj69)
It refers to the crank position where the valve is open a given amount (usually specified at .050" or 1mm of valve lift).
On the intake cam, it specifies the crank angle before top dead center of the start of the intake cycle where the valve is open that .050" or 1mm amount.
I've never worked with the stock B18B cams, so you got me.
Old Feb 25, 2004 | 05:30 PM
HmgLauj69's Avatar
Default Re: Intake Valve Opening Crank Angle BTDC (IN VTEC)
so would that mean the crank degree would be different depending on valve lashing?
Old Feb 25, 2004 | 05:37 PM
Fuxican's Avatar
Your intake valve should open .050 at around 28-32 degrees BTDC. Thats what it should be for any normal four cycle motor.
Old Feb 25, 2004 | 05:45 PM
HmgLauj69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 &raquo;</TD></TR><TR><TD CLASS="quote">so would that mean the crank degree would be different depending on valve lashing?</TD></TR></TABLE>
Old Feb 25, 2004 | 05:56 PM
Fuxican's Avatar
When you increase lash, you effectively decrease the cam duration. It will changed the valve opening marginally, but shouldnt change the intake centerline.
Old Feb 25, 2004 | 06:03 PM
HmgLauj69's Avatar
Default Re: Intake Valve Opening Crank Angle BTDC (Mexicutioner)
oh...cool, i think i understand it now
DC4_MADMAN
Nov 20, 2006 04:36 PM
vietdragontekx
Apr 21, 2006 10:40 PM
houstondigital
Aug 8, 2005 09:23 PM
LshatchTurbo
Aug 12, 2002 03:28 PM
XDEep
Jul 2, 2002 07:30 PM
