installing rods and pistons question
Old Dec 4, 2008 | 03:04 PM
delsol8017's Avatar
Default installing rods and pistons question
is there any good diy links around here. i tried looking but came up with nothing as usual. if not can someone tell me how? how hard is it on a scale of 1-10? tips? etc etc
Old Dec 4, 2008 | 04:04 PM
blackeg's Avatar
its nott that hard to be honest with you. im pretty sure jeff evans has a good write up and maybe even a video of it on his website. www.evans-tuning.com. check for it
Old Dec 4, 2008 | 04:14 PM
98vtec's Avatar
moderator emeritus
just be careful when sliding the compressed rings into the cylinders. Done correctly, they will slide into the bore very easily without much pressure. Do not force them in as you run the risk of damaging the rings. The autozone ring compressors are horrible. I would advise purchasing something like the ARP tapered ring compressors. Also be careful with the rod ends and dont let them hit the bore on the way down, they can gouge the bore and thats not good.
Old Dec 4, 2008 | 07:37 PM
srmofo's Avatar
honestly I find this cheap lisle brand compressor to be pretty damn good
....make sure you give the compressor a little tappy tap-tap against the block to make sure it is square before you drive the piston in.....something else that might help a first timer is to put a couple of pieces of rubber hose over the rod bolts to keep them from hitting the crank....its real easy to nick the crank, trust me......I would say the most difficult/time consuming part is plastigauging the motor and filing the rings.....I hate doing that ****, takes forever and you cant really rush it or take any shortcuts
1320london
Engine Machining & Assembly
Jul 26, 2016 07:13 PM
krazydbiker
Mar 24, 2007 02:24 PM
thsmrtone1
Jan 21, 2007 02:02 PM
Turbo95Hatch
Oct 6, 2006 11:44 AM
808b18c1boosted
Feb 5, 2004 03:58 PM
