what spark plugs
Old Dec 2, 2008 | 06:37 PM
teamworxek9's Avatar
Default what spark plugs
just wondering what spark plugs people are running. just looking for other ideas, i am using ngk's.
Old Dec 4, 2008 | 01:20 PM
Perfectionist's Avatar
Unless you are severely modded, use the plug that is spec'd for your engine. Check the owner's manual, or sometimes it's indicated on a lable under the hood. NGK or Denso only. Stay away from 'gimmick' plugs.
Old Dec 4, 2008 | 07:40 PM
JNocon's Avatar
If you're using NGK's, is it a #5 heat range? Depending if you want to use Platinum, Iridium, etc. I'm using a colder plug NGK #6 and timing is retard by 2-3 degrees.
mickey513
Jun 19, 2014 08:38 PM
Lovemy99Lude
Jan 31, 2009 09:25 PM
deacs
Oct 1, 2002 10:33 AM
mattmw88
Feb 22, 2002 07:54 AM
