Installing pistons
Old Jun 18, 2002 | 08:21 PM
EGHatchy's Avatar
Default Installing pistons
this might be a newbie question, but can someone tell me how to install pistons? is there important details I should know?
Old Jun 18, 2002 | 08:34 PM
Rocket's Avatar
Default Re: Installing pistons (EGHatchy)
This sounds like a cliche but get a Helms manual. It will be the start of a beautiful relationship.
You'll need a piston ring compressor and space the ring gaps according to the manual. Also rods go one way. They fit the other way but that's not good.
Old Jun 18, 2002 | 09:23 PM
C-speed's Avatar
check here:
http://www.c-speedracing.com/howto/b.../b20vtec2.html
Old Jun 19, 2002 | 12:33 AM
kinesistech's Avatar
Its a pretty involved process. You need to completely disassemble the engine because with new pistons you need new rings, and new rings need a freshly honed block. So once you got them out of your engine, you need a shop to press out the wrist pin from the old rod/piston and press it through the new piston and your rod. Then its rebuild the engine from there. So, yeah the helms is a really good idea.
Old Jun 19, 2002 | 12:36 AM
Kamin's Avatar
Default Re: Installing pistons (kinesistech)
if you dont know what your doing get a helms
if you KNOW what your doing get a helms.
follow it STEP BY STEP!
http://www.helminc.com
redsolturbo
May 27, 2009 09:51 AM
kaj
Jan 24, 2004 06:56 PM
speedysir
Aug 31, 2002 11:49 PM
GruvyTune
Jun 2, 2002 03:34 PM
gsr squirrel
Mar 21, 2002 04:50 PM
