Installing chip?!
Old Apr 24, 2003 | 08:34 PM
93solsigsr's Avatar
Default Installing chip?!
I am thinking about getting a chip for my ecu, I was just wandering how hard it is? I have done just about every other thing on a car but have never tried it, anyone ever done this? Any suggestions, should I get a shop to do it?
Old Apr 25, 2003 | 10:14 AM
HRTuning's Avatar
Default Re: Installing chip?! (93solsigsr)
OBD1 ECUs are easy... No desoldering needed for most of them... So it'll be fairly easy for you if you can solder...
Old Apr 25, 2003 | 01:14 PM
shermanyang's Avatar
Default Re: Installing chip?! (HardLowrdRanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardLowrdRanger &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 ECUs are easy... No desoldering needed for most of them... So it'll be fairly easy for you if you can solder...</TD></TR></TABLE>
you may need to desolder some of the solder that's in the holes before you start soldering the chip in. it makes life a lot easier.
Old Apr 25, 2003 | 01:18 PM
HRTuning's Avatar
Default Re: Installing chip?! (shermanyang)
lol, it's so normal to me i don't even think of it as desoldering anymore... Only when there's a chip to take out... woops... i stand corrected... If you can desolder/solder...
Old Apr 25, 2003 | 07:08 PM
ChiBoy's Avatar
It's not THAT hard, if you can de-solder and solder. The de-soldering is more difficult IMO. I used and old ECU to learn on and made a mess of it by the time I was done. The first real ECU looked fine after that. If you're not real confident in your skills, I would have someone do it for you.
Jax99SI
Apr 9, 2008 12:59 PM
93supercoupe
Apr 27, 2007 06:02 PM
xDicktonesx
Oct 4, 2006 11:26 AM
Kwuaymaikrup
Apr 1, 2004 08:11 PM
omahaturbocivic
Aug 1, 2003 10:04 AM
