installed the distributor wrong
Old Nov 28, 2006 | 08:58 PM
myhondasux's Avatar
Default installed the distributor wrong
hey guys, i need a little help.
i just changed my coil and as i was putting the distributor back on, i accidentally forced it back on in the wrong direction, tightened it, and cranked it over. i have since corrected it but now its still not starting and its cranking over funny. Its cranking over very fast as if i dont have compression. do you think installing the distributor in the wrong orientation could cause significant damage?
i took off the valve cover to make sure i didnt snap the cam or anything but it looks fine.
what do you think the problem could be?
Modified by myhondasux at 9:30 AM 11/29/2006
Old Nov 29, 2006 | 01:09 PM
evosix's Avatar
Default Re: installed the distributor wrong (myhondasux)
i think that could jack up your timing.. how long did you run it that way?
Old Nov 29, 2006 | 07:20 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhondasux &raquo;</TD></TR><TR><TD CLASS="quote">
... Its cranking over very fast as if i dont have compression...</TD></TR></TABLE>That part sounds like a broken timing belt. That should probably NOT be related to forcing the distributor, but maybe you forced the camahaft to move???
Old Nov 30, 2006 | 04:01 AM
dfoxengr's Avatar
Default Re: installed the distributor wrong (JimBlake)
happened to me when i was 17 or so. the timing belt just skipped some teeth most likely.
get that fixed and youll be fine.
Old Nov 30, 2006 | 07:49 AM
myhondasux's Avatar
Default Re: installed the distributor wrong (dfoxengr)
thanks for your help guys, that was the next thing i was going to check.
Old Nov 30, 2006 | 08:34 AM
charlee's Avatar
Old Nov 30, 2006 | 08:48 AM
Azn Kenny's Avatar
Make sure you check the timing on the cam gears AND the crank pulley.
dopefeen
16
Mar 12, 2007 10:34 AM
92integra-R
Mar 27, 2006 10:23 PM
dlowdog
Dec 30, 2005 11:07 AM
uNF$@#!
Mar 28, 2004 11:48 PM
steve_s
Jul 2, 2003 08:36 PM
