Distributor Replacement
My distributor on my 92 Civic CX is making nosie. Took off the cover and found a red film caked inside the cover. From looking at other boards, looks like i am smoking a bearing in the housing. I am going to try to get a new distributor tommorow and put it in. How involved of a job am I looking at? ANy pointers or things to look out for?? Can I see the timing marks without removing the timing belt cover?? I will greatly appreciate any help. Looks like a good board here. Its going on my favorites. Thanks alot guys!!
Derek
Derek
Just go to autozone and get a new Dizzy (Lifetime Replacement) and rent a timing get and install the distributor a little loose and redo your timing to what it calls for in the manual
Imperious: Mod of Valor
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Just go to autozone and get a new Dizzy (Lifetime Replacement) and rent a timing get and install the distributor a little loose and redo your timing to what it calls for in the manual</TD></TR></TABLE>
Exactly. Just make sure you get the ignition timing as it is now and you're golden.
1 Post
Re: Distributor Replacement (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">Distributor King</TD></TR></TABLE>
