Inserting the pistons from the bottom?
Got the answer - thanks.
I have the motor in the car. Dont feel like pulling it out but well if the following not possible or not recommend for various reasons. If all I want to do is change the pistons out could I just drop the oil pan, crank, rods and pistons ... change the pistons - reconnect them to the rods and assemble everything back together all from the bottom of the motor.
Thanks
Matt
A hone is not necessary. This motor has not yet been started. Brand new. I just am thinking about a higher CR piston.
Modified by tunedek at 12:10 AM 5/1/2005
Modified by tunedek at 11:15 AM 5/1/2005
Thanks
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">How exactly do you plan to hone to block?</TD></TR></TABLE>
Cordless electric drill with some kind of attachment rigged to it
My concern in the rings and pins if inserting the piston from the bottoms is going to affect them anyway. I dont think so but im 100% sure.
you cant pull the pistons out the bottom. they will not fit passed the mains.
hell you cant even pull the crank out without removing the transmission.......and if your gonna go through the trouble of removing the tranny in another 20min you could have the whole engine out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">you cant pull the pistons out the bottom. they will not fit passed the mains.
awww true true - the mains. see i just wanted to know. thanks for you help i have my answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by probinator »</TD></TR><TR><TD CLASS="quote">I would buy a first gen Probe.
I would let this shitty thread die
</TD></TR></TABLE>I would let this shitty thread die
riceball777
Oct 10, 2005 09:21 AM
