injectors all the same?
Old Nov 24, 2001 | 11:23 PM
hondur guru's Avatar
New User
Default injectors all the same?
Say I were to buy some 300cc injectors that were intended for a civic. Can I also use these 300cc injectors in my celica? This is not really a specific engine question. I am just trying to figure out if injectors are made specifically for every type of engine.
[Modified by hondur guru, 8:25 AM 11/25/2001]
Old Nov 25, 2001 | 05:13 AM
rainforest's Avatar
Default Re: injectors all the same? (hondur guru)
it depends if you have a 0bd 0 car or a obd 1-2 car here are some that will work on both that around 300cc.
92-96 preludes 345cc and will work on pre obd cars.
97-00 preludes 280cc will work on obd 1/2 cars
Old Nov 28, 2001 | 02:36 PM
iwhichisme's Avatar
Default Re: injectors all the same? (rainforest)
which prelude injectors will work for pre obd cars, vtec?
Old Nov 28, 2001 | 04:17 PM
fsarfino's Avatar
Default Re: injectors all the same? (iwhichisme)
no there are two types saturated and peak and hold you can tell the diffrence with a ohm meter one type has a higher restince not sure which one is higher though
Someone else care to anwser that for me ????
Old Nov 28, 2001 | 05:07 PM
DoobieEF8's Avatar
Default Re: injectors all the same? (dohcvtec16)
alot -most of car manufacturers dont use the same fuel rail. there are high impedence, low impedence. i wouldnt consider all injectors to be universal or transferable to other models.
Old Nov 28, 2001 | 11:39 PM
Giuseppe's Avatar
if u have a preOBD car(peak and holdinjectors), and running an injector resistor
box...... OBD1 prelude injectors are a nice swap....
HTH
Old Nov 28, 2001 | 11:41 PM
Giuseppe's Avatar
It easy to test which injectors you have - just put a multimeter on resistance and put the probe on each of the 2 terminals of the injector (+ probe on one pin, - probe on the other). If it reads 2-3 ohms, you have a LOW IMPEDANCE, PEAK AND HOLD injector that requires a RESISTOR BOX. If the resistance reads 11-12 ohms, you have a HIGH IMPEDANCE injector that does NOT require a resistor box.
Old Nov 29, 2001 | 05:07 PM
evo's Avatar
evo
New User
Default Re: injectors all the same? (Giuseppe)
Is it possible to transfer H22A VTEC injector direct into B16A without mod?
Old Nov 29, 2001 | 07:52 PM
initial-d's Avatar
How much work is it to change the fuel injectors?? How much does it usually cost for parts and labour? I did an obd2 to obd1 swap, so does this mean I need to change my fuel injectors?
Dave2094
Jul 13, 2008 08:17 AM
MidoriEK4
Mar 2, 2003 02:53 PM
simple4012
Sep 3, 2002 07:11 PM
Powered by Honda
Oct 12, 2001 10:07 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
