? injector seals for s2 rail
i purchased a s2 composite fuel rail and the stock injectors seals wouldnt fit it just busted them. so i went to the local napa and theres was the same way. anyone else had this problem and how did u cure it
what u mean broke them? the instructions with mine said they should fit like stock but the RC injectors seemed to fit loose in the rail and way tight in the IM. i just lubed and had to start the seal half way on the injector and slide in.
thanks the seals are more round than flat. i tryed to lube them up and they kinda off ripped a strip off the gasket and it leaked. im going to try some oem honda probally today to see if they work
RTW DC2R
May 3, 2006 05:41 AM
