Injector multiplier
Old Nov 12, 2001 | 05:23 PM
Lyonel's Avatar
Default Injector multiplier
On http://www.hondata.com/techtuning.html they mention tuning the a/f mixture by adjusting the injector multiplier. What is it? What does it do? Can it be tuned manually or do you have to tap into the ECU?
TIA
Old Nov 13, 2001 | 07:05 AM
FSTASNTZ's Avatar
Default Re: Injector multiplier (Lyonel)
It is a calibration program within the Hondata program. It bases the result off the initial injector size, new injector size and new fuel pressure.
It is not something you can get your ECU to do without having it reprogramed...
Jason
Old Nov 13, 2001 | 09:50 AM
Davep's Avatar
It's the overall multiplier of the entire fuel map. Each value in the map is multiplied by it. So if you change your fuel injectors from the stock 240cc (multiplier is 1) to 450cc injectors, it will change your multiplier to .533 to compensate for the larger injectors. This is something that you set up in the ROM editor with the rest of the maps etc.
[Modified by Davep, 1:51 PM 11/13/2001]
Fnix
May 17, 2012 03:04 PM
codenamezero
Engine Management and Tuning
Jun 12, 2011 12:50 PM
Rotten Egg
Aug 1, 2008 10:14 PM
EJ8chu
Apr 9, 2008 03:44 AM
c61lude
Jan 28, 2005 07:27 PM
