indentifying B series transmissions..........
Old Aug 16, 2002 | 12:52 PM
HondaCutter's Avatar
Default indentifying B series transmissions..........
A friend of mine just recently bought a tranny for his swap from a not so local junk yard. The tranny is supposed to be from a later model GSR. IS there any way that I can identify the transmission? Any castings that would let me in on what year or model? Thanks, just a little worried that this guy might have sent him a ls tranny thinking he wouldnt know any better.
Old Aug 16, 2002 | 08:26 PM
Default Re: indentifying B series transmissions.......... (HondaCutter)
bump
Old Aug 16, 2002 | 08:37 PM
91DA9's Avatar
There should be a letter and number combo on a sticker with a barcode. I don't know of any place where it is actually casted into the tranny case.
Old Aug 16, 2002 | 09:44 PM
3rdGteg's Avatar
Default Re: indentifying B series transmissions.......... (94IntegraGSR-OVR)
The only way is to throw it on and drive it; the gsr revs up faster than an ls. How much are those trannies going for at the junkyard (gsr's)?
Old Aug 16, 2002 | 09:53 PM
Reddog's Avatar
Default Re: indentifying B series transmissions.......... (3rdGteg)
Just thinking....what if you ran the serial number on it at your local police department that should tell you the year and type of car. I think the serial number is the one next to the tranny code, I might be wrong, anyone know if thats the serial number?
Ryan
[Modified by Reddogallmtrcrx, 6:53 AM 8/17/2002]
Old Aug 16, 2002 | 09:57 PM
91DA9's Avatar
Default Re: indentifying B series transmissions.......... (Reddogallmtrcrx)
Ryan
The tranny should have a VIN on it. Which could easily be checked through Carfax.
Old Aug 16, 2002 | 10:02 PM
Reddog's Avatar
True there you go. Skip the police..where is the vin
Old Aug 16, 2002 | 10:31 PM
Malgerus's Avatar
I could very well be wrong, but isn't there an identification tag on the top front of the transmission, on the side of the block stamp on the engine? Like my brother's B16 swap: his tranny is an S1, and the code reads "S19083-whatever-"....
Old Aug 16, 2002 | 11:18 PM
ninesecrx's Avatar
Default Re: indentifying B series transmissions.......... (89_Y_49)
you could always open it up and count the gear teeth. that would tell you regardless of everything else.
Old Aug 17, 2002 | 08:30 PM
3rdGteg's Avatar
Default Re: indentifying B series transmissions.......... (ninesecrx)
well I'm about to open mine up, how many gear teeth are there in the gsr?
cranker
Aug 10, 2010 09:31 AM
ALL B SERIES
Aug 23, 2005 08:27 AM
S@nt0s
May 7, 2004 04:48 AM
4g4me
Aug 16, 2002 12:55 PM
