Im having some problems
Old Dec 2, 2003 | 08:45 PM
Big Josh's Avatar
Default Im having some problems
I just got my car back from the shop and I am having some problems. Nothing I believe he did, but here's whats going on.
The motor is:
b18c
dart block
crower rods
je pistons 9:1 compression pistons
stock crank
stock cams
ferra valves. std
310cc injectors
drag turbo kit
stock ignition
I think that should be enough info for now.
When I get on the car alittle bit the car will start to cut out at about 5000 or so. The check engine light comes on and throws a 3-map sensor, 22-v-tec pressure switch, and a 43-fuel supply system code. The car does this at as little as 2 pounds of boost. Under 4 grand the car is fine I can let it hit 15 pounds and have no problem. I have plenty of check valves going to the map sensor and before the rebuild I had no problem with 10psi all the way to rev limiter.
I am alittle confused on what to do or look for.
Please help!
Old Dec 2, 2003 | 09:00 PM
Big Josh's Avatar
Default Re: Im having some problems (Big Josh)
any one?
Old Dec 2, 2003 | 09:20 PM
Big Josh's Avatar
hello
Old Dec 2, 2003 | 09:52 PM
PHiZ's Avatar
this is a swap? Is your knock sensor hooked up?
-PHiZ
Old Dec 2, 2003 | 10:05 PM
hybridEj6's Avatar
Default Re: Im having some problems (PHiZ)
HONDATA will solve all or most of your problems
mrflak0
May 2, 2010 10:02 PM
jaredvabeach
Honda Civic (2001 - 2005)
Jan 20, 2009 05:59 PM
...:::MaRk:::...
Jul 16, 2008 07:33 PM
EG6_TyeR
Oct 15, 2004 12:34 PM
