Ignition Timing B16A
Old Aug 6, 2006 | 06:40 AM
gawinter_2000's Avatar
Default Ignition Timing B16A
Can anything else cause the ignition timing to be out other than the cam timing?
My distributor is turned as far as it will go towards the firewall and still can't quite get the timing marks to line up.
I have checked the cam timing numerous times and it looks spot on.
Are there any sensors that could cause the ecu to adjust the timing?
The car is a DelSol with a B16A engine. Idles nicely, runs fine when cold, but loses power when warm.
Any help is appreciated.
Old Aug 6, 2006 | 01:20 PM
postman's Avatar
Default Re: Ignition Timing B16A (gawinter_2000)
cam and crank not lined up correctly
Treyschls
Apr 13, 2023 07:04 AM
kirkland08
Feb 13, 2011 08:59 AM
johnwohl
Apr 1, 2008 07:29 PM
SiRhatchy
10
Aug 11, 2005 05:06 PM
donnjuan2point2
Mar 11, 2004 10:49 AM
