advance timing...what does it do?
1 Post
Re: advance timing...what does it do? (JDM-97CX)
Well I'm going to assume you meant ignition timing.
Ignition timing is measured in degrees BTDC (Before Top Dead Center). Top dead center is when the piston is at the very top of it's stroke. If your timing was 16 degrees BTDC then when the plug fired the crankshaft would still have to turn 16 degrees to get the piston all the way up.
Advancing your timing is not the greatest idea if you don't know what you are doing. The gains from it are normally pretty minimal compared to the risk.
1 Post
Re: advance timing...what does it do? (SiRhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRhatchy »</TD></TR><TR><TD CLASS="quote">because my b16a, the distributor was advanced, and i adjusted it to the middle and it runs weaker now...</TD></TR></TABLE>
Well did you check the timing with a timing light or did you just see that it was advanced on its mounts?
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRhatchy »</TD></TR><TR><TD CLASS="quote">no, i just saw that it was advanced</TD></TR></TABLE>
You need to check your timing with a timing light because it might have needed to be there to be in spec.
allnaturalb16
21
08-14-2007 08:57 PM
Attoir
03-18-2004 01:25 PM
VSM EXtasy
07-19-2003 10:19 AM
