ignition timing
my ingnition timing was retarded 5 degrees
could i have damaged my engine in any way or should there be somthing i should look for that i might have f-ed up?
BTW its a b18c1 it was at 11 degrees now back to 16 degrees
could i have damaged my engine in any way or should there be somthing i should look for that i might have f-ed up?BTW its a b18c1 it was at 11 degrees now back to 16 degrees
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fokis05 »</TD></TR><TR><TD CLASS="quote">my ingnition timing was retarded 5 degrees
BTW its a b18c1 it was at 11 degrees now back to 16 degrees</TD></TR></TABLE>
Uh... your ignition was too far ADVANCED not retarded... 11degrees btdc is further forward in the stroke then 16degrees btdc.
could i have damaged my engine in any way or should there be somthing i should look for that i might have f-ed up?BTW its a b18c1 it was at 11 degrees now back to 16 degrees</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fokis05 »</TD></TR><TR><TD CLASS="quote">thats good! how much of a loss of hp are we talking here if i was 5 degrees retarded? </TD></TR></TABLE>
Not much if any... but like I said above your's was advanced not retarded so you probobly lost a little up top...
My car was soo advanced it was pinging like a beotch... I retarded it and you can't tell any difference at all... other than the lack of pinging.
bonylad
Jun 14, 2006 09:19 AM
VSM EXtasy
Jul 19, 2003 10:19 AM
