Shifting Problem. Bad Clutch
Old Jul 20, 2003 | 08:41 PM
tegmaniac's Avatar
Default Shifting Problem. Bad Clutch
Recently my car has been chattering when I start off in first and the the car will not let me go into gear when shifting at higher rpms and it is still notchy at low rpms. It happens with every gear and there is no grinding so I pretty much ruled out the synchros. Any ideas as to what part in the clutch assembly is causing this? Thanks for any tips.
Old Jul 22, 2003 | 08:43 PM
tegmaniac's Avatar
Default Re: Shifting Problem. Bad Clutch (tegmaniac)
bump. Any help please?
Old Jul 22, 2003 | 11:05 PM
VtecDA9's Avatar
i'm having that same problem... I was told it was the clutch.... either your disc is shot or if you need a clutch adjsutment... but doubt it at that point... need a new clutch... My clutch makes this squeek getting our fo first gear, I can drop into 3rd at 80mph anymore and i get a wrotten egg smell....
Old Jul 23, 2003 | 08:13 PM
tegmaniac's Avatar
Default Re: Shifting Problem. Bad Clutch (VtecDA9)
thanks for the tip. I already ordered a new clutch kit. That will be a fun project. Has anyone pulled their tranny with car on jack stands or do you have to have a lift?
LS_VTECteggy
Dec 21, 2009 05:22 AM
snakepirates
11
Jun 9, 2006 01:40 PM
94teggieGs-r
Aug 18, 2005 10:29 PM
93civcx
Jun 18, 2004 06:25 AM
