ignition timing
Old Mar 29, 2006 | 04:16 AM
Project_99Hatchback's Avatar
Default ignition timing
hey i'm just wondering how you set the base ignition timing on a 99 civic stock d16 sohc non vtec 5spd where is the timing marks and what do i ground out to disable the computer? and what should the base ignition timing be?
Old Mar 29, 2006 | 03:06 PM
Rico's Avatar
The mark that you are looking for is on the crank pulley, its the red mark. To disable the ecu you need to go to the right-hand side of the dash and look for the plug just put a paperclip in the plug and set the timing. Do a search under timing and it will take you step-by-step to set the timing..
Old Mar 29, 2006 | 09:06 PM
alright thanks man i'm sure it's a repost but for some reason i suck at searching
Old Mar 30, 2006 | 05:05 AM
EE_Chris's Avatar
Default Re: (Project_99Hatchback)
The plug you're looking for under the passenger side dash is the same plug you use to check ECU codes. Short it out, start the car - check engine light will be on, no worries though.
Use a timing light hooked up to the #1 cylinder. Shine it down towards the crank pulley. There is a pointer on the timing belt cover that you look 'through' to see where the timing mark is. There are 3 red marks - the center is stock setting with the outter two being + and - 2*. Loosen the distributor a little and rotate to achieve what you want. I'd put a reference mark on the distributor and the head just to show where you initially were.
1mistashank
May 29, 2009 08:17 PM
killacam661
Jun 28, 2008 09:13 AM
NSfit
10
Nov 14, 2006 11:17 AM
Neutex22
Jan 13, 2005 10:17 AM
dsCRXsi
May 2, 2004 04:32 AM
