ignition problem on eg
Old Feb 11, 2004 | 09:45 PM
89EF9's Avatar
Default ignition problem on eg
alright fellas help me out
92 Civic Vx 125K bone stock
here's what i've replaced since i've had the car, to try and solve the problem.
-plugs
-wires
-cap and rotor
-distributor
-timing belt
-water pump
the scenario.
alright my car idles fine so no vaccum leaks, also no codes thrown. i'll be driving down the road and unless i'm all the way on the gas or all the way off it'll sputter hesitate, miss, whatever you wanna call it. cannot maintain cruising speeds in this thing at all. if i am halfway on the gas it won't accelerate at all. it feels so much like ignition. checked the tps and signal was good from closed all the way up to wot. so i put the thing on the Sun 450 at school and ran ignition scope, everything looks good. checked impedance on all four injectors. checked the fuel pump by pulling the vac. hose off the reg. so then i thought the timing might be off. recently changed t belt and h20 pump, timing was in spec and is now. but still hesitates.
It will only miss when under a load (actually driving down the road.)
It runs like a champ when not in motion
my ?
Would The EGR system effect this hesitation to accelerate?
any other suggestions on what to check?
TIA
Jeremy
Old Feb 16, 2004 | 01:39 PM
89EF9's Avatar
Default Re: ignition problem on eg (89EF9)
also forgot to add that it does not do this when the engine is cold.
bump.
Old Feb 16, 2004 | 05:12 PM
notstock93's Avatar
check the fuel filter and check for cracked or unplugged vacuum lines, it may not effect your idle as bad as you think. I would also swap out the MAP for one that is known to be good and see if that has any effect on your situation.
Casey Smith
Honda Civic (2001 - 2005)
Nov 20, 2017 02:32 PM
Boss727
45
Feb 23, 2014 07:51 AM
aqprider
Sep 14, 2013 06:28 PM
Built2NV
May 8, 2011 08:19 AM
acatak
May 23, 2003 12:00 PM
