ignition problem
Old Dec 2, 2008 | 06:31 PM
dohcvtec92's Avatar
Default ignition problem
I gotta 92 hatch dx with an 01 integra gsr swap when u first crank the car it skips like 4 a few seconds then when the engine light comes on it runs fine. The car also has msd ignition cap, coil, and 6al box with a apex vafc.
Old Dec 2, 2008 | 06:40 PM
teamworxek9's Avatar
sounds like you are misfiring is everything installed right, what about the firing order. tough to answer without hearing it.
Old Dec 3, 2008 | 05:56 AM
mtber's Avatar
Check your malfunction indication codes & get back to us.
Old Dec 3, 2008 | 10:35 AM
dohcvtec92's Avatar
It was showing an 8-which should b a TDC sensor and then the light came on for a longer time then went off and done it again then it flashed 2 times but i cant remember what that 1 is, i took off all the msd and it still done it after that
Old Dec 3, 2008 | 11:17 AM
Ubertec's Avatar
Pull the distributor and check the shaft. 1)does it spin round smoothly and 2) is there excessive side to side play?
code 1 is primary o2 sensor.
Old Dec 3, 2008 | 01:26 PM
mtber's Avatar
Replace the distributor.
Tony the Tiger
Oct 17, 2009 06:01 AM
gsrt
Jul 18, 2008 11:38 AM
stivic
Feb 14, 2006 03:55 PM
quicky_hatch12
Aug 24, 2005 06:01 AM
GTEater
Jun 24, 2001 02:58 PM
