External msd coil better?
Old Aug 21, 2005 | 06:36 PM
quicky_hatch12's Avatar
Default External msd coil better?
Yea I have a gsr and for about a week I couldn't figure out why my car boggs out at high rpm. I changed my distributor coil and It was find. It ran perfect. The thing is when my car is hot my car begins to bogg again. I was wondering if the external msd coil would be better and will allow my car to get full power at all times.
Old Aug 21, 2005 | 07:02 PM
Default Re: External msd coil better? (TurboLiLcIvIc605)
Could this be the reason my car boggs at high rpm when its hot?
Is the coil in my distributor not strong enough?
Would the msd external solve this problem?
Old Aug 22, 2005 | 11:31 AM
ironcheftony's Avatar
maybe your o2 sensor is going bad
Old Aug 22, 2005 | 02:27 PM
msmotorsports's Avatar
Since it is heat related it may be the ignitor. I know alot of ignitors fail when temps get high. Try an external coil.
Old Aug 22, 2005 | 07:27 PM
Default Re: External msd coil better? (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Since it is heat related it may be the ignitor. I know alot of ignitors fail when temps get high. Try an external coil.</TD></TR></TABLE>
yea thats what i thought it was because i replaced my coil and it runs strong *** hell until my car gets hot then vtec kind of sputters and my car boggs. I was told that and external msd coil would stand against the heat better than my oem coil.
Old Aug 24, 2005 | 06:01 AM
R-Toyz.com's Avatar
Check your distributor cap as well. My car had the same symptoms as your car...and acted up once the motor warmed up.
I purchased a refurbished distributor, but the car still acted up. My problem turned out to be my cap, a screw was missing and the cap wasn't seating properly.
I went with an external coil since I don't trust the refurbished unit's igniter and coil (probably cheap taiwanese made ones). If I had a strong OEM dizzy I wouldn't bother with an MSD.
Kilpuri
May 25, 2009 06:59 AM
crazyc@SRTmotorsports
Mar 12, 2007 03:14 AM
Truecure
May 19, 2005 10:13 AM
Sick'Lude
Jan 16, 2005 11:43 AM
unFOB4U
Aug 17, 2002 08:44 PM
