AIC valve problem
Old Dec 15, 2001 | 09:52 PM
ITR41's Avatar
New User
Default AIC valve problem
ok, my ECU is throwing a AIC valve check engine light. I replaced the AIC valve today the AIC is still throwing check. with lopy idle and all....could it be my ECU? maybe a shorted wire? I didn't unplug the battery so should I do that and see if it resets the ECU? need help asap guys.
Old Dec 16, 2001 | 04:15 PM
Kenso's Avatar
HT White Ops
Default Re: AIC valve problem (ITR41)
I assume you are referring to the IAC (idle air control) valve. You may want to check your idle speed adjustment. If the idle is set too high, the idle will fluctuate rapidly up and down as the IAC tries to compensate. Also make sure you don't have any vacuum leaks which would cause idle problems. I'm not sure if either of these conditions would set an IAC code though. Something to look at anyway.
fano
Mar 4, 2011 11:39 AM
ViZ
Jan 16, 2011 02:05 PM
thunderboy
Jan 27, 2008 10:24 AM
Victor
Dec 1, 2004 10:29 AM
Rhetoric
Aug 1, 2003 04:31 PM
