idle drops when let off gas in neutral or push clutch in
1988 CRX DX
GS-R block
B16 head
LSD Trans
bolt ons and such. let me know if you need mroe info to helpme figure out this issue...
So if i rev in neutral and let off the gas, the RPMs drop way below idle. it doesnt kill the car but it drops LOW. same thing when im cruising and depress the clutch. RPM's drop and go LOW, then come back up to idle. it isnt smooth coming back up to idle either. sometimes it bounces a little. sometimes it idles low. this is especially bad when the motor is cold. but still does happen when the motor is warm and the idle is up a little. i dont really have a very good idea of what this could be... fuel injectors maybe? idk...
GS-R block
B16 head
LSD Trans
dang. that pretty much narrows it down to everything i already had in mind...
anybody else have a similar experience and found the issue?
just looking for a way to narrow it down. dont really feel like tearin the whole thing apart you know? been there, done that. on many different occasions.
Have you ever messed with the TPS? If not, check the following. Hopefully you will find the problem early. Start by replacing any regular maintenance items that you haven't serviced in awhile- filters, ignition parts, etc. and clean your grounds. Next, check the ignition. Disable the injectors and get a new or known good spark plug. Wear gloves (welding gloves work great), preferably with latex or nitrile gloves underneath, and remove a spark plug wire from its plug. Connect the good plug to the end of the wire and hold the plastic deep-well tube at the very tip of the wire end with the threads of the plug touching bare metal on the valve cover. Have an assistant crank the motor while you watch the spark, carefully keeping all body parts away from the plug. Different types of plugs have different colored sparks but usually a good spark is bright pink or at least bright. Check all four wires. This will test your entire ignition. Finally, either check your fuel pressure or replace the pump, saving the receipt. Sorry I can't be more specific but a weak idle like yours can really be caused by alot of different things. This will at least give you a full engine tune up and afterward you will know everything is working great.
just recently did ignition switch.
had fuel pump out i know it works. but since its a stock pump with a poormans type R... maybe its lagging a little?
recently replaced fuel filter.
it might need plugs... but its got some bad *** wires.
i think the alternator is a little weak... could that be the problem?
thanks for the advice.
im also dealing with something like this. car idles fine 4 me tho, just when i clutch the idle drop below idle+even dies at times. does this when car at all times sitting or in motion.
if im sitting in the car running in neutral and i push the clutch in, i dont believe it effects the idle at all, except for maybe bumps it up a smidge. im talking about when im cruising in gear, say 3rd, and push in the clutch. of course at that time the car is essentially in neutral, and the rpms should drop to idle. but in my car, ist almost as if the speed of the rpm drop carries it past idle, until it bounces back up. catch my drift?
If your motor struggles when you press the clutch while in gear but not when in neutral then your clutch is probably not releasing completely. Check the clutch hydraulic system. See how far the slave cylinder is moving the release fork.
i have a cable clutch. im sorry i didnt mention that before. my idle also struggles when i just rev and let off the gas. it drops below and then bounces back up... so this is wierd.
bump for the same exact problem, i have a 90 crx hf with a h22 swap. I was originally have an idle problem that was all over the place. to try to fix my sporatic idle I have just recently taken of the intake manifold, cleaned everything with carb cleaner, and replaced both the IACV and FITV with new units. Now my idle no longer contantly jumps anymore, instead its doing exactly what is descibed in this thread. Any help please? I'm tired of spending money.
i was havein the same prolbem in 92 ek gsr. but it would go from 1500rpms or 2000rpms but last night i check my oil and i was soooo low. i put in a hole bottle and this morning my idle was fine rite at 900rpms or jus a lil higher. i have a lil noise in the top right part of my head sounds like something loose or something i was told a vaulve agust. but idk.....plez help....
You need to check the screen on the eacv and make sure the throttle body is cleaned out. You make even have a bad eacv.
looks like this but yours may be mounted on the backside of the intake
my integra does this also. but mine seems to only due that when im pulling big amperage. drove my car for a few days without my stereo on to let the battery charge up and it stopped. drove afterwards with my my stereo jamming and it started doing it again after a day or so of heavy jamming.
[QUOTE=AcurInteg96;45991064]my integra does this also. but mine seems to only due that when im pulling big amperage. drove my car for a few days without my stereo on to let the battery charge up and it stopped. drove afterwards with my my stereo jamming and it started doing it again after a day or so of heavy jamming.[/QUOTE
I also have this problem in my 98 gsr. I think it might be that the alternator is on its last days
I am having this issue now,, well ive had it for a while now actually and ive tried replacing many things, IACV, FITV, spark plugs/wires, Distributor cap/ rotor, battery lol,,
when i come to a stop sign and put the clutch in, my idle drops down as if it was going to die but it bounces back up to like 700 rmps..
@88CRXJ, did you ever resolve the problem? and if so what else did u try?
i need to FINALLY fix my dc2! i cant think of anything else
ahaha any help will be appreciated.
Also i have not replaced my Alternator and i believe mine is taking a poop, does anyone know if replacing that did them any good?
Thanks again!
Thanks again!
hm... that sounds like something completely different than what is happening with my car.
My type R has exactly the same problem
So far I have tried:
A different ECU, 2 known working IACVs, new leads, new dizzy cap and rotor, new plugs and I have checked the timing belt has been set correctly.
has anyone had any lucky finding out this problem?
I have also had my compression tested, the results were:
Cylinder 1: 225psi
Cylinder 2: 225psi
Cylinder 3: 190psi
Cylinder 4: 200psi
Would this variation in compression cause a bad idle? It uses no water and only has a little bit of oil smoke on vtec.
I have also seen this thread:
https://honda-tech.com/forums/tech-misc-15/valve-adjustment-issue-car-stalls-3145667/
Which seems like the exact same problem. Yet I haven't checked my clearance yet.
Check your valve clearances. My CRV was one of the ones that had the sinking exhaust valves. When the clearances were too tight, the idle was terrible and the car would sometimes stall. I changed everything and that didn't fix it. Valve clearances were what did it. It's easy and free to check. Do it!
Sonny
Sonny
[QUOTE=88CRXJ;40825203]dang. that pretty much narrows it down to everything i already had in mind...
maybe just try idling up the car with the screw in the throttle body and also adjust ignition timing. It's what I had to do to mine. Make sure ur throttle cable is somewhat limp what letting off the gas and ur idle is only controlled by the idle screw pin
Yes, sounds like its bout time to give the IACV some sweet sweet lovin'. I dont think it would be timing if it was running fine and just starting doing it.
