Idle
Old Aug 2, 2003 | 09:53 PM
Fatty_1775's Avatar
Default Idle
Here is what's happening. When the car is started, it idles from 900 to 1400 and back. It repeats. The only time I can get it to stop, is while I'm holding down the brake, I go into first, let the clutch go just enough so the idle drops to 900 and I leave it there for a few seconds. Go back into neutral and let go of the clutch and the idle stays there. Once I tap on the gas, or drive away, the weird idle happens again. Anyone experience this and have any thoughts? Thanks.
Old Aug 3, 2003 | 07:42 AM
Fatty_1775's Avatar
Default Re: Idle (Autobot_Killer)
did a search too
Old Aug 3, 2003 | 09:18 AM
preluder's Avatar
it can be a number of things computer,iacv,tps sensor,coolent bubbles in the system,vacuum leak.
Old Aug 3, 2003 | 10:27 AM
Aron Parsons's Avatar
Try adjusted your idle speed first (screw on the TB). If it's getting too much air, the EAVC can't control the idle and that is where the surging comes in. After you adjust the idle, reset your ECU as well.
Old Aug 3, 2003 | 07:06 PM
Fatty_1775's Avatar
Default Re: Idle (Aron Parsons)
My idle was fine before, and then it started doing it. I didnt even touch anything under the hood. how could this happen? vibration?
Old Aug 3, 2003 | 08:35 PM
quik1's Avatar
Sounds like your fast idle valve. Warm your car up take your air cleaner off check to see if there is vacune coming out of the top hole in your throttle body, if there is then its your fast idle. Make sure your car is up to temp first though. Good luck.
Old Aug 4, 2003 | 03:43 PM
Fatty_1775's Avatar
Default Re: Idle (quik1)
air cleaner? as in the pipe connected to the throttle body?
Old Aug 6, 2003 | 05:32 PM
quik1's Avatar
Yup
mouastar
Jul 7, 2011 12:21 PM
spock_rocker
Oct 17, 2007 08:11 AM
97hb
Jan 24, 2003 11:12 AM
