Identify these componets?
Old Jan 31, 2014 | 10:21 AM
DeeJHonda95's Avatar
Default Identify these componets?
What is this?
What is this?
Old Jan 31, 2014 | 01:00 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Identify these componets?
Look like some type of evap components
Old Jan 31, 2014 | 01:01 PM
cetcivic's Avatar
no one wants to hear the truth
Old Jan 31, 2014 | 01:25 PM
m4xwellmurd3r's Avatar
A small Carbon canister and purge valves from the looks of it
Old Jan 31, 2014 | 01:55 PM
One is hook up to the secondary butterflies.. But I also have two purges?? One is by the injectors and one is next to the MAP as shown in the picture
Old Jan 31, 2014 | 08:33 PM
My 90 integra has two purge valves hooked to the carbon canister. One is hooked inline with the fuel regulator, the other is hooked inline with the map sensor. At least, I think thats how its hooked up
Old Feb 1, 2014 | 02:23 AM
HondaPartsHero's Avatar
Technical Hero
What is your year make model and engine
Old Feb 1, 2014 | 04:59 AM
I have a 95 civic nd I'm doing a H22A OBD1 swap in it..
Old Feb 2, 2014 | 05:14 AM
Technical Hero
Old Feb 2, 2014 | 06:46 AM
I actually got the same diagram from all data but my question is there is a solenoid in between the fuel pressure regulator to the intake.. But it doesn't show that in the diagram... Should I just do away with this extra component and run FPR straight to the intake?
Old Feb 2, 2014 | 10:13 AM
Technical Hero
Which ECU are you going to be using? Because a lot of those components can be trashed if you aren't using the P13 ECU.
Old Feb 2, 2014 | 01:21 PM
I am using p13 unfortunately
Old Feb 3, 2014 | 01:34 AM
Technical Hero
Ok then you'll need to wire up the IAB's and run the vacuum routing for it as well as the EGR system. You could save yourself a huge headache by running a P28 with a P13 basemap. You could eliminate the knock, IAB's, and EGR items altogether.
Old Feb 3, 2014 | 09:16 AM
e0325's Avatar
^^^ what he said
Old Feb 4, 2014 | 03:16 AM
Wouldn't I have to put a plate on egr? Or just leave it be?
boostedcivicsir
Oct 26, 2008 02:14 PM
shaggyeg6si
May 15, 2008 07:48 AM
tgreaves
Dec 3, 2003 12:08 PM
pelotudo
Aug 23, 2002 09:09 PM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
