Ideling issues!!!
Old Jul 31, 2002 | 11:17 AM
DaddyFatSacks's Avatar
Default Ideling issues!!!
When i'm ideling, my RPM drops and the car feels like it's about to stall but it never does. Anyone every had this problem or know how to fix it?
Old Jul 31, 2002 | 11:40 AM
Spade's Avatar
Default Re: Ideling issues!!! (DaddyFatSacks)
Adjust idle.
Disconnect IACV with car running.
Turn Idle adjustment screw on Trottle body till desired idle is reached.
Run car until engine fan turns on.
Shut car off, connect IACV and clear ecu codes.
Turn car on and leave alone until fan turns on again.
Old Jul 31, 2002 | 11:53 AM
Default Re: Ideling issues!!! (Spade)
thanks...
one thing that i didn't mention, it goes up and down. for example, it goes from 800 to 300, the whole time fluttering.
Will your solution still work?
Old Jul 31, 2002 | 12:18 PM
Spade's Avatar
NOpe.
I also have a fluctuating idle.....I just completly bypassed the IACV and adjusted idle to 850....fluctuates down to about 500 and up to 850 now.
Old Jul 31, 2002 | 01:27 PM
great, thanks.
much appreciated!
Old Aug 5, 2002 | 02:52 AM
NZcrx88's Avatar
hi
what is IACV? where it is?
Thanks
[Modified by NZcrx88, 11:53 AM 8/5/2002]
Old Aug 6, 2002 | 11:30 AM
jetdriven's Avatar
Default Re: Ideling issues!!! (NZcrx88)
my 91 ls auto would do the same thing. I backed the idle screw all the way out with no change. Turns out my exhaust can was off a tooth, and it was losing vacuum at idle. I reset the cam and it runs perfect. if you recently did the timing belt that might be your problem.....easy and free fix too.
dc4b20
22
Dec 3, 2012 09:54 PM
jah.tien
Jul 14, 2010 10:37 AM
carblegal
Dec 25, 2004 09:51 PM
killa_lude
Aug 16, 2003 08:33 AM
