ICM
Old Feb 16, 2006 | 09:06 AM
E_LOW's Avatar
Default ICM
is there a ignition control module on a 95 LS 1.8 non vtec?and if there is where is it located?
Old Feb 16, 2006 | 10:24 AM
tgreaves's Avatar
Default Re: ICM (E_LOW)
In the dizzy.. Its the little part that has like 5 wires going to it..
Old Feb 16, 2006 | 11:34 AM
tallyturbo's Avatar
Default Re: ICM (tgreaves)
yep if you take the dizzy cap off, unscrew the screw that holds on the rotor, take off the rotor, then take off that black shrouding, then look at the coil, after you see the coil look right below it and you will see it. like said above it has 5 wires going to it.
A13sechatch
Jun 8, 2010 09:10 AM
B-outAteam
Sep 6, 2009 06:38 AM
jonnyt1130
Aug 3, 2009 04:55 PM
n00bs suck
Dec 9, 2004 08:47 PM
Acura_I-RS
Jun 6, 2002 03:57 PM
