IACV & MAP
Old Aug 29, 2005 | 11:50 PM
MenaceL.A.671's Avatar
Default IACV & MAP
how can i tell if my IACV and MAP sensor is bad... because my idle (when engine is warm) goes up and down up and down... and goes away after a min. but it happens when im at a stop. so im assuming its might be the IACV and MAP sensor.. anyone..?
Modified by m2slsvtec at 6:46 PM 8/30/2005
Old Aug 30, 2005 | 12:05 AM
Default Re: IACV & MAP (m2slsvtec)
anyone???
Old Aug 30, 2005 | 05:47 PM
nothing.... cause ima score one on ebay...
Old Aug 30, 2005 | 05:51 PM
slomofo's Avatar
GDD Member
Check for vaccuum leaks and air bubbles in cooling system.
Old Aug 30, 2005 | 06:01 PM
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Check for vaccuum leaks and air bubbles in cooling system.</TD></TR></TABLE>
i bled the coolant... but what vaccum u talkin about???
Old Aug 30, 2005 | 06:03 PM
mmuller's Avatar
Mad Scientist
Default Re: (m2slsvtec)
as sayd above; bleed the system, clean out the iacv
Old Aug 30, 2005 | 06:07 PM
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">as sayd above; bleed the system, clean out the iacv</TD></TR></TABLE>
the iacv.. is clean out... well i dont know if its the map or iacv is fucked.. cuz when i started the car... and put off the harness off the map.. the car died out... is that normal... or does the car suppose to at least bogg... but i didnt try pulling off the harness off the iacv... soo well see...
Old Aug 30, 2005 | 06:19 PM
slomofo's Avatar
GDD Member
Try swapping plugs with MAP/TPS. You might've mixed the plugs up.
Old Aug 30, 2005 | 06:24 PM
the harness is correct... cuz my throttle sensor works on my vafcII&gt;...
Old Aug 30, 2005 | 06:52 PM
PrettyLude's Avatar
i would think it would be your fitv, it needs to be adjusted, if you are saying it only does this when it is warm
Old Aug 30, 2005 | 06:53 PM
mmuller's Avatar
Mad Scientist
if you pull the plug off the map, the car will die.
If you pull the plug out of the iacv, the idle should drop low
Old Aug 30, 2005 | 06:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">if you pull the plug off the map, the car will die.
If you pull the plug out of the iacv, the idle should drop low</TD></TR></TABLE>
yup...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i would think it would be your fitv, it needs to be adjusted, if you are saying it only does this when it is warm</TD></TR></TABLE>
fitv?? the one on the iacv???
Old Aug 30, 2005 | 07:05 PM
ima goo **** around with it again... dayum.. typoon is passing the island today.. i cant really work... im just doing testing..
Old Aug 29, 2009 | 11:24 AM
HondaSPEC99's Avatar
I have the same problem. Some people told me it was a bad IACV they told me to clean it or replace it! I said im not goin to spend the money on a new one! I have an after market Skunk2 Intake Pro-series and 68mm TB on my D16y8... IACV needs to be cleaned!
(My idle is bouncing from 1500-2000rpm when stopped) I have tried the screw for the air flow of the IACV but it dint seem to do anything! So my thought was the IACV is F***d!!!
JBirch_97Prelude
Apr 20, 2007 06:39 AM
aut0tek
Jan 4, 2005 10:28 PM
hatchinprogress
Nov 23, 2004 08:21 PM
Race Egr
Apr 5, 2004 10:32 PM
FourthGenHatch
May 19, 2003 10:51 AM
