IACV causing issues
Old May 26, 2018 | 07:48 AM
autox19's Avatar
Default IACV causing issues
History. b16 in a fiat x19. over heated (235 ish). after I towed it home and started it, my tunerview RD-1 wouldnt show readings. from the ECU. Also noticed the IACV was buzzing. Unplugged the IACV and the RD-1 started showing readings. tried cleaning the IACV with same result. I had another manifold laying around so I plugged that in (didnt bolt it in) readings every time (at least 10 tries) swapped the coolant hoses and bolted it on.
now when I plug it in I dont get a buzz, but I get no readings again. unplugged it and I get readings. I dont get any error codes.
what to check next?
Odie
Old May 27, 2018 | 05:49 AM
autox19's Avatar
Default Re: IACV causing issues
Oh do I wish I could delete this thread. Forever proof I am a moron. Start with basics. The data plug on the ECU that feeds the rd-1wasnt on all the way. Might have vibrated off. Going to try to isolate the ECU better.
odie
Claudio Guzman
Jan 13, 2019 02:16 PM
scuffywin
Feb 2, 2008 05:06 PM
ludatic
Nov 2, 2003 10:46 PM
shylilpimp
Oct 23, 2003 05:29 PM
