cant get any codes from the ecu
Old Nov 2, 2003 | 07:32 PM
ludatic's Avatar
Default cant get any codes from the ecu
its like this. My lude has a hunting idle so i go to check for codes in the ECU, i do the jumper thing and the check engine comes on but doesnt go out. does this mean no codes are in the ecu or is there a prob with the ecu. see, i thought if no codes were in the ecu it would do the one flash hello thing then nothing for no codes. someone let me know. thanx
Old Nov 2, 2003 | 10:13 PM
CleenSi
Guest
Posts: n/a
Default Re: cant get any codes from the ecu (ludatic)
unplug the negative wire on the Battery, then plug it back in after a minute or so, if the light doesnt shut off theni dotn know what to tell you.
Old Nov 2, 2003 | 10:46 PM
Hybridize's Avatar
Constant led = Code 0 Ecu malfunction..
Sorry man but it sounds like your ecu is bad...
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
bk7794
May 29, 2012 09:32 AM
conesmasher
Aug 31, 2004 09:12 PM
CleanLIttleLude
Jun 13, 2003 12:09 PM
