IAC problems plz help!!
Old Aug 6, 2003 | 11:55 PM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default IAC problems plz help!!
Im getting CEL code 14, which is IAC i dont know whats causing the problem.. the sensor is pluged in but wut im not sure of is if the wires r going to the right pins on the ECU, i have an H22A swap in a 93 CX, using the CX harness, coverted wut was needed from the information given by poison. im currently running a p28 chipped in my car, so if you guys have any information on where the wires suppose to go on the ECU, that would be very thankful, CEL is pissing me off.. its the only code.. B4 i was throwing 3.. so its the last one.. help me out guys!!! thanks !!!
Old Aug 7, 2003 | 09:47 AM
turbo*s2k's Avatar
Default Re: IAC problems plz help!! (H22AEG)
Does it throw it all the time? You might just need to replace the IAC. I use to get that on my civic back in the day, but it wouldn't come on all the time. I ended up replacing it, and now no more problems. I would double check that wiring too, but I don't think that's the problem...
Old Aug 7, 2003 | 11:10 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG &raquo;</TD></TR><TR><TD CLASS="quote">Im getting CEL code 14, which is IAC i dont know whats causing the problem.. the sensor is pluged in but wut im not sure of is if the wires r going to the right pins on the ECU, i have an H22A swap in a 93 CX, using the CX harness, coverted wut was needed from the information given by poison. im currently running a p28 chipped in my car, so if you guys have any information on where the wires suppose to go on the ECU, that would be very thankful, CEL is pissing me off.. its the only code.. B4 i was throwing 3.. so its the last one.. help me out guys!!! thanks !!!</TD></TR></TABLE>
See if you have the IACV plug and IAT plug (on #1 intake manifold runner) mixed up....they use the same exact round plug and sometimes they can get crossed and mounted to the wrong sensor.
Old Aug 7, 2003 | 11:27 PM
aaaabbbb's Avatar
where exactly is the IAT sensor?
THANKS FOR THE HELP!!
Old Aug 8, 2003 | 09:56 AM
Katman's Avatar
Default Re: (H22AEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG &raquo;</TD></TR><TR><TD CLASS="quote">where exactly is the IAT sensor?
THANKS FOR THE HELP!!</TD></TR></TABLE>
I forgot where it is on an H22 engine, but its usually found either on the top side of the intake runners (tubes) or on the backside of the intake manifold. Usually a white plug.
here's some pics of where it would be located on a B-series engine:
https://honda-tech.com/zerothread?id=578718
Old Aug 11, 2003 | 01:50 AM
aaaabbbb's Avatar
white plug.. its on the side of the manifold, i thinks its pluged in right.. but ill switch to make sure thanks
4g4dcruisin
Feb 14, 2010 07:23 AM
rickturboteg
Oct 2, 2006 10:23 AM
jdoggmr2
Jun 25, 2006 03:44 PM
THEUSED
10
Apr 26, 2006 12:50 PM
HavokB18
Jul 12, 2004 08:08 AM
