iab?
Old Aug 28, 2006 | 03:02 PM
Frisco-EG6's Avatar
Default iab?
i just recently purchased a gsr b18c1 motor. and i noticed it didn't come wit that iab black box like this:
do i need this box to run the motor or not? (actual pic is not mine)
Old Aug 28, 2006 | 06:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: iab? (Frisco-EG6)
Without the IAB connected, the intake will use the short runners, resulting in lost low and mid RPM torque. You can either install the IAB or install an aftermarket IM.
Old Aug 28, 2006 | 09:36 PM
Frisco-EG6's Avatar
Default Re: iab? (Dogginator)
right on 4 the reply but the thing is the black box is not there but the solenoid is still there n vacuum lines is still conected to the solenoid???
Old Aug 29, 2006 | 03:46 AM
Dogginator's Avatar
Daisy... Daisy...
You could make a vacuum canister for the IAB. It looks like you need a check valve (part #4).
http://www.acuraparts247.com/p...ch=no
Old Aug 29, 2006 | 03:02 PM
Frisco-EG6's Avatar
oh ok. the way mine is set up hose #15 runs from the #3 t-fitting where #14 and #4 used to be to the #6 solenoid where #9 hose is supposed to be. #17 hose is still in the same place. i just wanna know if i could run it like this or just buy the iab black box???
oh yea the motor is a '95
Modified by Frisco-EG6 at 12:32 AM 8/30/2006
Old Aug 29, 2006 | 03:16 PM
Frisco-EG6's Avatar
please help!!!
Modified by Frisco-EG6 at 12:29 AM 8/30/2006
Old Aug 29, 2006 | 11:36 PM
Frisco-EG6's Avatar
Old Aug 30, 2006 | 04:10 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frisco-EG6 &raquo;</TD></TR><TR><TD CLASS="quote">oh ok. the way mine is set up hose #15 runs from the #3 t-fitting where #14 and #4 used to be to the #6 solenoid where #9 hose is supposed to be. #17 hose is still in the same place. i just wanna know if i could run it like this or just buy the iab black box???
Modified by Frisco-EG6 at 12:32 AM 8/30/2006</TD></TR></TABLE>
You need a check valve and a vacuum storage canister as shown in the diagram. Vacuum is accumulated in the canister at closed throttle. The IAB operates at WOT, where little intake manifold vacuum is available.
JDMEJ!
Aug 31, 2012 02:14 PM
sirb16a
Feb 4, 2009 04:04 PM
Boost2NA
Mar 30, 2004 06:20 PM
Boost2NA
Mar 29, 2004 05:32 PM
00WhiteEKy
Aug 25, 2002 11:13 AM
