i need a CEL code deciphered plz
Old Jul 11, 2004 | 04:13 PM
WillsH22Accord's Avatar
Default i need a CEL code deciphered plz
I have a jdm H22A, and the code im flashing when i connect the current on the blue plug from the ecu is: 4 flashes, each lasting about one second, then a very subtle and quick flash. if you guys know the codes id appreciate the help
Old Jul 11, 2004 | 05:06 PM
JoseCuervo's Avatar
Default Re: i need a CEL code deciphered plz (WillsH22Accord)
WillsH22Accord;
The long flashes are 10's (i.e. 4 long flashes = 40)
The short/quick flashes are 1's (i.e. 2 quick ones = 2)
When done, it pauses for 2 seconds and commences sequence again.
For what you're saying, you're throwing code 41.
OBDI = Oxygen sensor heater - check heater for the proper voltage reading
OBDII = Primary heater O2 sensor heated circuit fault (Sensor 1)
Hope this helps!
Old Jul 11, 2004 | 05:59 PM
unsungsohc's Avatar
Default Re: i need a CEL code deciphered plz (JoseCuervo)
https://honda-tech.com/zerothread?id=682412
Old Jul 11, 2004 | 06:09 PM
thanks, thats exactly what i thought it was, but i was unaware that when the o2 ssensor goes, it goes into a safe mode. thanks for your help
civicboy1128
13
Nov 7, 2013 11:50 AM
GEIJIN
Aug 7, 2009 07:56 PM
tai
Sep 19, 2005 08:10 PM
Qwikrex
Jun 22, 2002 12:52 PM
Rival
Nov 3, 2001 07:57 AM
