I have no reverse. WHY? Plz Help
Old Feb 24, 2006 | 05:18 PM
vtec25's Avatar
Default I have no reverse. WHY? Plz Help
i have a S4C and its wont go into reverse no matter what even when car is off. It'll shift fine into all other 5 gears though. What do ya think could be the problem and/or the solution???
ThankX
Old Feb 25, 2006 | 04:45 AM
IN VTEC's Avatar
Default Re: I have no reverse. WHY? Plz Help (vtec25)
Likely problem: damaged 5th-reverse synchro sleeve
Solution: Replace 5th-reverse synchro set, check 5th gear for damage (replace as needed), and recheck mainshaft thrust clearance
Cost: ~$120 for the synchro set and probably another $70 for a replacement 5th gear (if needed)
PM Dan GSR. He's in NY and might be close enough to do the work for you....at a price, but it won't be too bad.
Apex1972
Dec 27, 2009 11:55 PM
cd5-pete
Oct 28, 2008 04:33 PM
JDM B16A
11
Mar 18, 2006 03:44 PM
maxpsi
Jun 16, 2003 01:40 PM
eg_nezay
Feb 3, 2002 09:05 PM
