Hunting EG6 on idle. Help required please.
Old Jun 17, 2005 | 08:22 AM
John F's Avatar
Default Hunting EG6 on idle. Help required please. Check light help needed also now ! ah
My EG6 started to hunt on idle but not that badly. I replaced the O2 sensor and cleaned out the throttle body and it made it a little better but its still there.
About to clean out the idle control valve but anything other to look at ?
Modified by John F at 9:43 PM 6/17/2005
Old Jun 17, 2005 | 11:16 AM
John F's Avatar
Just cleaned out the IACV and its still hunting.
What else can i do and also how do i do the check light thing to see if there is any faults ?
Old Jun 17, 2005 | 12:16 PM
Kendall's Avatar
Check for vacuum leaks.
Old Jun 17, 2005 | 12:44 PM
John F's Avatar
will do thanks, but where is a likely place to check? Whats the best place to start?
Old Jun 17, 2005 | 05:38 PM
_BEN_'s Avatar
Default Re: (John F)
Pull one line at a time from your intake manifold.
Then cover the hole (on the intake manifold) with your finger. If it stops hunting you found your leaky line.
Also make sure that the plate in your throttle body is mating up good.
Another thing that could leak is the seals around your injectors.
Old Jun 17, 2005 | 05:41 PM
PrettyLude's Avatar
get a can of carb cleaner and spray it everywhere, if the engine starts to sounds funny when you are spraying the carb cleaner, there you found a vacuum leak
also check to make sure you get all the bubbles out the coolant
luv2boost
Jun 2, 2008 06:33 PM
PhilMac
Jan 14, 2008 11:35 AM
h22831
Jul 18, 2005 06:36 PM
thundergrey94ls
Jul 9, 2005 04:43 PM
digitalspice
Feb 20, 2002 02:35 PM
